this feature is completely broken.
- when dividing a room, why can you select multiple rooms?
- sometimes when moving the dividing line it says "place line inside the room to be divided" when there are clearly parts of the room on either side of the line.
- sometimes when clicking the tick mark when dividing a room it says "Reset failed"
why don't you just allow us to draw a rectangle and assign the enclosed are to a particular room, instead of all this line-drawing nonsense?
What do you mean select multiple rooms?
Could you send us a picture of the "reset failed" error message? Also, you can send us a picture of the current map and mark the layout you want on the map.
Also, clear the cache on the app, switch to cellular data to have a try.
issue 1 "when dividing a room, why can you select multiple rooms?"
why does it allow multiple rooms to be checked? it doesn't make sense.
"Reset failed"
here's the map: notice how the top-right room has blue pixels from the bottom-right room in it. this causes the robot to navigate to the red rom when it's only supposed to clean the blue room. so, i want to divide the blue room here, and then merge the top few pixels into the red room:
but, when i click 'ok', it just puts up an error:
clearing cache doesn't help, it's not a network issue.
Hi, thanks for your reply. It seems that the divide room line is placed on the white room which has walls all around it. That may be the cause for the failure.
In your case, maybe you can set a no go zone on the blue pixels to stop the robot from wanting to get inside the blue pixels.
