it keeps switching maps!
i have a map for both upstairs and downstairs. but now, when i take my 5smax downstairs, restore the downstairs map and tell it to clean, it automatically switches to the map to the upstairs map and proceeds to destroy it - putting new rooms on it that's don't exist. i have tried repeatedly to stop cleaning, restore the downstairs map, and start cleaning again, but it keeps switching.
the hardware for this thing is amazing, the software is complete garbage. fix it.
  • HI, sorry for the inconvenience caused.
    Actually the robot can scan its environment to figure out which floor it's on and uses the corresponding map to clean automatically. In other words, it won't follow the map you selected.
    Please check if the steps you've taken to create the multiple floor maps are correct or not in the first place.
    1. Tap the "Edit map" button on the bottom right corner of the map, and choose "My Map" from the pop-up banner.
    5. Make sure the robot is now located on the other floor. Then press "Create", and "Clean". The robot will speak "Starting to clean". Please wait until it completed the cleaning, and don't manually move the robot or interrupt the process.
    You can check the attached photos for your reference.
Spongman
