I have the Roborock s6 Pure. I already have my house mapped every time i go to clean a specific room it says no map found and then says positioning; going back to doc. then tries to create a new map. I then try to delete the map and restore the original map of my house and the process repeats. I've checked for anything in the robot and emptied the dust bin. I also have tried zone clean up and entire house clean up and not luck. Any Help would be great thanks.
i get the same error with my s5 max. i move the bot downstairs, restore the downstairs map in the app, and then tell it to clean. the first thing it does is clear the map and says "no map found" and "positioning..."
Hi, thanks for your reaching out.
The reason why the issue occurs may be the configuration of the downstairs has changed. We suggest you delete the map of the second floor and then remap it so that the robot can understand the latest environment.
