support-us@roborock.com
1-855-960-4321
Helpline hours: 24/7, US only
Compared with Qrevo EdgeT, Qrevo Edge 2 introduces several core feature upgrades:
Qrevo Edge 2 delivers up to 25,000 Pa of suction and uses an anti-tangle DuoDivide™ main brush plus a FlexiArm side brush for powerful cleaning. Its auto-lifting main brush module enables it mop floors without vacuuming, while the auto-lifting and mopping module allows hassle-free carpet cleaning in vacuum-only mode. It also features SmartPlan 3.0, Roborock's next-generation intelligent cleaning planning system, which learns your home layout and cleaning habits to automatically suggest and run personalized cleaning plans. The system supports multi-floor mapping, zone-based cleaning priority settings, and real-time adjustments via the mobile app. Set it once, and the robot handles the rest.
1. Spiral arc-shaped structure: significantly reduced tangling rate
Qrevo Edge 2 is equipped with a front-facing camera that enables both obstacle avoidance and video calling. Its structured-light sensor plus RGB camera can identify over 280 types of obstacles and detect dirty areas.
The multifunctional dock of Qrevo Edge 2 supports high-temperature mop washing at up to 80°C (176°F) and offers a Soak Mop Washing mode as well as mop cloth detachment. It also features mop drying at up to 55°C (131°F), along with automatic dust emptying and automatic water refilling.
Under typical use, Qrevo Edge 2 operates at about 64 dB, roughly comparable to the hum of a refrigerator or everyday conversation.
It offers up to 190 minutes of runtime (*based on internal manufacturer testing under these conditions: quiet mode, hard floors, fully charged battery, and without the mopping module installed. Actual performance may vary depending on your home environment and the cleaning mode used. )
It comes with a 5,200 mAh built-in battery and takes about 4 hours to charge from 15% to full.
1-855-960-4321
