Soap in the water tank
I have the Roborock S6 vacuum cleaner.
I wanted to know if soap can be put in his water tank and if so what kind of soap is recommended?
  • Hi, usually, we don't suggest our customers add anything into the water because the bubble made by chemical substance in cleaner may block the filter and cause no water out.
    Customers could give it a shot. If all is fine, we think it is OK to add. But if anything wrong on mopping, please clean the tank with water and don't use the cleaner any more.
nurit
