S5 Upgrade and room selection
I just got my vac from Roborock after having to get fixed. By the way, the support process was great. When I got it back there was a FW update and I'm trying to get my room cleaning setup. Does the vac have to do a complete cleaning before you can use it? Any documentation on the setup?
  • Hi, We are glad to hear that you like the new firmware version. You could ask your robot do a complete cleaning before you divide the room.
    There are 4 requirements for robot to create a complete and new map:
    1. Map
    saved mode is enabled, see attached pic.
    2. Robot starts from dock;
    3. Robot goes everywhere on map it detects to clean, not just somewhere;
GAPRocker
