S5 Max side sensor sensitivity’s
Hi All
This my sharing after 2 days of S5Max usage. Compare to Mi Vacuum, the side sensor Is
not that accurate, S5M use to knock my table leg, and the same small space Mi Vacuum can enter and S5M not entering. As the laser positioning is not same so this might happen. Why this can be happen , it should be a improvement.
Colin_Orally
Mi Vacuum & S5 Max User - From Malaysia
