Firmware 3.5.8_0780 roborock s5 max
Hello. After updating to firmware 3.5.8_0780, the vacuum cleaner began to clean poorly, how can I return to the previous firmware?
  • Dear Customer,
    You can hard reset the S5 Max to get the original firmware. Instruction is listed as below:
    Step 2. Use a pin to press the reset button next to wifi LED just once,and power button, home button and spot cleaning button's light will be out. When you are doing this, please make sure home button is still under your finger's holding without moving.
    Notice:
    2. Factory default restore will also make RoboVac's firmware version come back to original one when it was made in factory. After factory default restore, you could go to RoboVac's setting--genera setting--check for updates to upgrade its firmware to latest one.
    Besides, you can provide more details about the current issue and then we can locate this issue and try to figure it out.
Rustique
