Roborock s6 maxv map saving
the app says the map saving is not enabled but I can't find a spot to enable it. It also says it saves it after cleanup but it needs to be enabled. But the enable setting in vacuum settings isn't there.
  • Never mind the button to activate it was almost invisible and I have a cracked screen so it was really hard to see
    RR_SupportStaff Member06/14/2020      07:25
    @Clearmist:
    Glad to hear that you figured it out.
    If you have any further question, do not hesitate to contact us.
Clearmist
