My roborock has an #8 error
I do not what to do... I cleaned after every time i use... help!!!!
    What is the model number of your robot?
    If robot says error 8 stuck issue when nothing around it, try methods below.
    1. Remember robot could not be moved by hands, or it will get lost in room and may say error 8.
    2. If error only happens in one place frequently, send us picture to show how the place looks like.
    3. Turn over robot to check if anything stuck in wheel and use hand to roll 2 wheels to feel if they are too loose or too tense.
    4. If water tank is installed, remove it to test if error appears.
Ale García
