Use S5 Max for multi floor
Is there an instruction on how to do multi floor cleaning with S5 Max. Should I create a new map for different floor?
  • Here is the brief description for how to use it:
    For the first map, when robot is creating the first map, there are 4 requirements to meet:
    1. Map saved mode is enabled.
    2. Robot starts from dock;
    3. Robot goes everywhere on map it detects to clean, not just somewhere. Please make sure the doors are open for the rooms you want to be displayed on map.
    For the 2-4 maps, please enable multi-floor maps feature first and click “create new map”, you don't need to move the charging dock together with the vacuum to the other floor. You just need to move the vacuum alone to map that floor. The vacuum will come back to the starting point where you let it start the cleaning, and store the new map. After all maps are successfully created, you don't need to carry the charging dock with the vacuum to the other floor. Just move the vacuum alone there, start the vacuum and it will recognize which floor it is, and use the corresponding map.
Ray
