Add Device in Mi Home for Robot Vacuum Model sdjqr02rr
I am not being able do connect with my Robot Vacuum in Mi Home app (Android). The automatic scan does not find the device. One thing is that doesn't seem to have the model of my robot in the list (v1 model sdjqr02rr).
It tries do scan without success. If I try the manual process, the Mi Home app switches to the Wifi config where I select the Wifi network of the Robot (rockrobo-vacuum-v1_miapAD67) but it doesn't advance after I select the network.
    Please select " Mi robot vacuum” and connect it to the Mi Home app then.
    jviveros
    jviveros09/08/2020      17:04
    Hi, I have the same problem with my SDJQR02RR. I tried 'add device' using 'Mi robot vacuum-mop' but it doesn't seem to work. The app keeps scanning without finding the vacuum cleaner.
    RR_SupportStaff Member09/11/2020      08:37
    @jviveros:
    Hello, could you tell us the serial number of the robot?
    jviveros
    jviveros09/15/2020      21:28
    It used to connect and work properly but I changed my smartphone and now I couldn't connect the robot again. Is the serial number any of the data in this picture?
RobotBrasil
