automatically switch from mopping to vacuum-only on carpets
S5 Max. The vacuum detects when it is on carpet and boosts the suction - why not use this same feature to automatically switch off mopping when carpet is detected, instead of relying on the owner to manually set no-mop areas?
  • becouse this function not work well, and many times vacuum not recognize carpets.
    becouse mop pad is still wet even is water is of, (after carpet detect) so a better solution would be for the vacuum cleaner not to run over the carpet while it moping, without using no mop zones.
    Ofcourse roborock first should fix "carpet mode" function.
    Kenneth
    Kenneth10/17/2020      06:43
    @VANT:
    Carpet mode works fine on my S6 . But since the vaccumer only have 1 side brush, which is what it used to recognize a carpet, it would only turn on carpet mode, if it goes over the carpet first, with the side brush...side!
christina
