carpet mode was on and you could here the brush stopping and it sounded like the suction motor was ramping up and down. you can also see the hair not being picked up most of the time.
We've added an internal protection design in the firmware updates.
When brush's running faces high friction like on a carpet for a certain period, the brush will stop running to protect robot. But the pause is temporary and the brush will resume running. The process will be in circle if brush keeps facing high friction.
That is reason why you may see robot's main brush or side brush stop running. When robot is running on carpet, the rolling brush and side brush are not helping collect stuff much and suction is the main tool. The suction strength will increase to max automatically when the robot reaches the carpet if you have enabled the carpet mode.
Could you send us a short video of the issue you mentioned?
Does it work well over the hard floor?
Hello!
here is a video. part 1
Meet Google Drive – One place for all your files
https://drive.google.com/file/d/1wm2FmyJxycgZ_aVmiX3Awl_r4sFKMKcq/view?usp=sharingpart 2
https://drive.google.com/file/d/1POgn1hXM2B4S50sgGHec-zENvQTlbmYF/view?usp=sharingcarpet mode was on and you could here the brush stopping and it sounded like the suction motor was ramping up and down. you can also see the hair not being picked up most of the time.
yes, it works well on hard floor
hope this helps!
Hope you can understand and forgive it.
ok i guess i’m going to return it because it’s not picking up stuff. thanks for the help anyway
