S6 MaxV gets stuck, then creates a new map!
I just got the new S6 MaxV, and love it. The only problem is that every time it gets stuck, and go’s to sleep because no one is around to immediately move it, when we move it and awaken it, it creates a new map!! How do we stop it creating new maps? Shouldn’t it be, once it creates the first map then there is no reason to mess with that first map?
  • 1. If error only happens in one place, send us a picture to show what the place looks like.
    2. Turn over robot to check if there is anything stuck in the wheel, and use hand to roll the two wheels to feel if they are too loose or too tight.
    3. If water tank is installed, remove it to test if error still appears.
    4.With mopping system installed, change the water volume to low to have a try.
WesleyJvR
