Turn off magnetic wall feature
In my apartment, there are some electric wires under the floor, which causes some unavoidable magnetic places, which block my S5 max from cleaning the floor. There is a magnetic place at a bedroom's door and that room cannot be cleaned. Is there any way to disable the virtual magnetic wall feature? If not, could you please add it to the app settings?
Thanks.
    Could you please check carefully whether there are any metal objects like screws stick to the bottom of the robot? See attached pic. If yes, please remove them. Many of our customers solved this problem by doing this.
    2. Does your robot report error 11 everywhere? If it's just in one area, you could use an app to test the magnetic strength of that area.
    Step 1. Search Magnetic Detector Lite on App Store (for iOS) or magnetic detector(for android) on Google Play and install it.
    Step 2. Move the phone from normal place to the position where the robot says error 11 to see if the level of magnetic rises sharply and alerts. Please lay down to the robot's height and move the phone to every place of the suspicious area several times as the app might not be very sensitive.
    Thieu
    Thieu02/08/2021      17:40
    1. There are no stick to the bottom of the robot.
    2. The robot never reports error 11.
  • Hi, you can also send us a video to show the robot's abnormal behaviour near the door. We'll forward the video to our tech team to see if they've any suggestions.
    Thieu
    Thieu02/08/2021      17:41
    Thanks, I will record and send the video soon.
    Thieu
    Thieu02/10/2021      11:19
    Please watch the following video:
    Thanks.
    RR_SupportStaff Member02/11/2021      03:28
    @Thieu:
    Hi, thanks for your reply. Could you please send us a screenshot of the history cleanup map of this round for our reference? It's possible the issue is not caused by the strong magnetic field.
Thieu
