Roborock is leaving tons of streaks. Any suggestions?
I've tried putting a new mop on it and adjusting the water level settings and its still steaking like crazy. I get less streaks with a new mop but it still leaves streaks when it turns. On the second time around with a new mop it starts leaving 7-10 streaks lines on everything it cleans not just the corners.
I was thinking of having it vacuum first then go around mopping to keep the mop clean. Should the mop be cleaned after every cleaning?
PristoMiky
