Hi May I know can I clean inside of the water tank?
We suggest you add water into the water tank, and shake it thoroughly to clean it.
If it's a bit dirty, you can use a little bit citric acid to clean it.
hi Roborock, I use this to clean it, ok?
https://shopee.com.my/Citric-Acid-%7C-Food-Grade-%7C-Anhydrous-%7C-Food---Pharmaceutical-Grade---Gred-Makanan---Farmaseutikal----Asid-Sitrik---%E6%9F%A0%E6%AA%AC%E9%85%B8-i.25341347.6564921238?gclid=CjwKCAjwjJmIBhA4EiwAQdCbxt94_qxyDJeIX8kh21DzWZpo0WaiqTFVTamsrDosX4DF4fJ9oDEgvBoCJAgQAvD_BwE
Hi, thanks for your reply. You can use a little bit of it, and please do not forget to dilute it before using it.
hi RR_support , after i put 3 pack of the citric acid, and wait for 2-3 days it now look very clean, thanks for your help
Hi, thanks for your updates! If there's anything we can help with, please feel free to contact us!
