Cleaning under furniture
I am thinking about buying Roborock S7 but I am worried about it cleaning under furniture - my whole kitchen and a few other pieces of furniture have got little pedestals at the bottom, lowest are 8cm from the ground and about 11cm deep.
I know that this is lower that the whole S7 height (including lidar tower) but I wanted to ask you whether S7 is able to slide itself into such gap - is the 8-8.5cm clearance enough to fit the base of the vacuum without the lidar, how deep into such gap can it enter and, the most important question, will it try to enter the gap?
Below you can see the gap in a foto, that's a view from the vacuum POV. ;)
Thanks.
  • I am looking for stylish paddles for canoes. It's hard to imagine how tough it can be to choose the right canoe paddle!
    I am thinking about buying Roborock S7 but I am worried about it cleaning under furniture - my whole kitchen and a few other pieces of furniture have got little pedestals at the bottom, lowest are 8cm from the ground and about 11cm deep. https://19216811.cam/
    https://1921681001.id/ I know that this is lower that the whole S7 height (including lidar tower) but I wanted to ask you whether S7 is able to slide itself into such gap - is the 8-8.5cm clearance enough to fit the base of the vacuum without the lidar, how deep into such gap can it enter and, the most important question, will it try to enter the gap?
    Thanks.
    issue got solved
linsChaho
