I. Please check if there's anything stuck in the wheels. You can press the wheels to see if they can depress and rebound freely and turn them to see if they can rotate freely.
II. If there's nothing stuck inside, please try the method below:
Notice:
Notice:
Mine is doing the same thing
https://youtu.be/MiBkw_lcTF8
Notice:
Notice:
