Roborock S6 max v: No voice, can't connect to its wifi
Hi folks,
I have a strange problem. It is a 1 year old roborock max v.
  • Unable to connect to roborock even after charging for 30 mins as I can't see its wifi network.
  • Every 20-30 mins i see power button flashing red while being charged
  • I tried resetting using spot cleaning and dock buttons , it didn't reset.
  • I was able to do a hard reset using a pin ,however, there was no voice/audio. and wifi indicator didn't show green light
  • No voice/audio when it is placed on the charger for charging
  • Charger switches on, i see see all 3 lights blinking slowly [ spot cleaner, power and dock] while being charged.
  • Rebooting, hard resetting is not helping
Anyone has faced this before? Any pointers? Appreciate any help
Cheers
    We suggest you factory reset the device to have a try.
snb
