Internal error: 105 left wheel short circuit - Model roborock.vacuum.a19 (S4 Max)
I need help. Error keeps occurring, even after I push/pull it for 10 seconds. The robot was purchased in June 2021.
  • You are not alone. I have the same issue with my S4Max. Mine is right at 1 year old as well.
    RR_SupportStaff Member08/21/2022      05:48
    @EAS:
    If the following method doesn't help, you can try a factory reset on the robot.
    https://youtu.be/MiBkw_lcTF8
    Notice:
    If neither the pushing nor reset won't address the issue, the device may need to be repaired. Please reach out to our support team at support@roborock.com to get further assistance.
CDell
