Brand New Out of the Box S7 maxv internal error
This thing doesn't work out of the box. All I get is error after error; cliff sensor error, internal error, and others. Can't even do a quick map. In fact, it cannot get out of the dock on its own. I called support and not much help. Told me I probably shouldn't have done an update before I tried it. The only option they gave was a factory reset. Same result afterward. I try to remote control and it will go forward and turn right, but cannot turn left or go backward. What can I do? Maybe just return it to the store.
    please try the method below:
    https://youtu.be/MiBkw_lcTF8
    Notice:
    If it's not working, it seems that there's something wrong with the device and warranty service is needed. Please get in touch with support@roborock.com to get further assistance.
Tom C
