Suggest a function to start Vacuum first in 1st pass then mop later in 2nd pass so I can select "Mop Route" during mop cycle and it will be cleaner since we vacuum all the dirt first before mop.
More advance function: can select number of pass for Vacuum and Mop cycle
For example: Select 1st cycle Vacuum - Suction Power Turbo
Select 2nd cycle Mop - Scrub Intensity - Moderate, Mop Route - Deep
Start Clean
*I know you can achieve it using scheduler or issue the clean command twice but it's better if we can do it on demand in a single command.
