Roborock Dyad has error E7
My Roborock Dyad run about ~2-5 mins, its show error with code = E7.
When E7: all the rollers are still spinning, but the vacuum cleaner stops.
If I turn off devices - about ~10 mins, its will work again, and after 2-5 mins, its show E7 (again and again....)
How I fix it?
Thank
    Could you please reboot your device for 3-5 times and then try again?
    (Note: hold power button for 5 seconds to force shutdown the device, and then press the power button to restart it)
    If issue persists, pls get in touch with our support team at support@roborock.com to get further assistance.
    Sim5266
    Sim526609/18/2023      07:38
    Hi, i have same issue and i try what u teach here already.
    hold power button for 5 seconds to force shutdown the device, and then press the power button to restart it - 3-5 times.
    The problem still the same. May i know is which spare part problem?
    Daniel
    Daniel10/01/2023      08:28
    @Sim5266:
    I have the same error E7 and reset machine is not working, i even replace the vacuum engine and it not fix the problem, can you tell me what to do?
nta139
