No - Mop area with S7
hello all,
I have the S7 pro Ultra and the only problem we have is, even after the robot vacuums the room including carpets, it still moves over the carpet when it is mopping the room.
I marked the carpet area on the map in the room but it ignores the carpet and moves on it, rising the mop doesn't work at all as it still waste time and power. When the Carpet zone is selected, it should keep vacuming the area but should not mop. (it should ignore that part of the room). When avoid carpet is selected in the map settings, the robot doesnt cross the carpet to an area where there is space to mop on the map. It just needs to notice the selected carpet area and move on it to cross (If there is no way around), not move on the carpet all the way.
Thank you,
Erolcet
