I'm experiencing a huge problem with my roborock v1 navigation system. I think it started a couple weeks after I replaced the main brush, and despite I don't believe there is a correlation with it, I thought it would help bringing to this post.
I already tried several fixing options like:
- factory reset
- deep cleaning cliff and wall sensors
- check if there was any occlusion on Lidar rotation
- changed dock station place to a more open space
- check if there was anything blocking some of the two wheels.
Nothing worked.
I first noticed when after a cleaning schedule the robot finished on a random place far from the dock, without telling there was a problem.
So I looked at the map and the path the robot made was completely random with no patterns. Now, every time I turn on, it keeps failing to navigate properly, doing some backwards movements really weird.
Attached there is an example of the map.
I have this model since 2018 and it is the first time I face an issue.
Hi thanks for reaching out.
Your question may not be solved in a short answer. We suggest you contact us via email: support@roborock.com. You could attach related pictures or videos in email for further help.
