Err 108 - Right wheel open circuit - QRevo
Hello, QRevo keeps having this error. How can I fix it?
    We are sorry to hear that your device did not work well. Please try the following:
    please try the method below:
    https://youtu.be/MiBkw_lcTF8
    Notice:
Autumn
