Weird movement and taking longer to finish cleaning
I’ve been experiencing difficulties with my S7 Max Ultra the last weeks after purchasing it for 2 months.
  1. I started notice it taking longer to finish the cleaning: it usually takes an hour for the 1st floor and now it takes 2.5 hours and can’t even get it to finish the cleaning because it runs out of battery.
  2. It started having weird movements and it goes outside the selected zones to do the cleaning
I didn’t change any settings and it worked perfectly before. Does anyone have any suggestions to fix this? Thank you!
Eddie
