Hello, I have a Roborock S5 robot vacuum - and it keeps coming up with an internal error - the message on the app says Error: 118 Right ODO error. I have rebooted the system twice, and also done a factory reset - but it's still happening. Please advise what I should try next
We are sorry to hear that your device did not work well. Please try the following:
please try the method below:
https://youtu.be/MiBkw_lcTF8
Notice:
I suggest cleaning the right wheel, checking for damage, resetting fnf calibration, and updating firmware.
