Hi Emma, there is no switch on hardware of robot nor software of app to turn on/off the mopping feature.
When water tank with enough water filled and mopping cloth are installed, the mopping begins working while it is moving. If water is out or water tank is removed, mopping stops.
Mop mode will cut down the vacuum strength to lowest and robot will still suck when mop mode is enabled.
While it will take effect once only, after robot finishes cleaning and backs to charge, the mop mode will change to the previous cleanup mode. 😊
Mop mode also known as gentle mode refers to the cleaning setting that allows a robot to mop floors with a softer touch. While some robots can mop without this mode enabling it ensures a more delicate cleaning process.
Recurring Home Cleaning in Newcastle
Hi Roborock,
Is there a way to turn off vacuum and just mop ? If not can the software be updated with this feature ?
Regards
Dileesh
Hi Dileesh.
There is no way to turn off vacuum and just mop, but we will forward your advice to our tech department.
Your feedback and understanding are much appreciated.
Thanks support team for the clarification and feedback
Regards
Dileesh
Introducing Guys01 Gaming Mod Apk, a groundbreaking custom program tailored for enhancing users’ gaming prowess within Stumble Guys.
