Unexpected obstacles on map
My map contains two small white areas where there are no objects. The vacuum always goes around these areas as if there was something there. Why doesn’t it see that the area is clear?
    May I know what this area looks like in reality? Is it under sofa or couch?
    You may try a zone cleaning which covers this area and try again.
Frank
