Mopping Feature Roborock S5
I have tried to look for the mopping feature on my Roborock settings under the “cleaning mode” how ever I don’t see the option to mop I just see, gentle, quiet, balanced, turbo and max.
the mopping attachment and water are attached to the vacuum can someone help me
  • There is no switch on hardware of robot nor software of app to turn on/off the mopping feature and control amount of water.
    When water tank with enough water filled and mopping cloth are installed, the mopping begins working while it is moving. If water is out or water tank is removed, mopping stops.
    Besides, there is no way to turn off suction or mopping to let just one of them work and the other one stop.
    The robot could not recognize the carpet and leave it away with water tank installed. I'm afraid you need uninstall them before it cleans the carpet.
  • Hi, it's the gentle mode in the app.
Speedy 11
