Hi, for the roborock s6, I have moved the dock to a new place in the map. The roborock doesn't go to the new dock instead in traces back to the old dock in the map and continues to search for it until it finds the dock. The problem is once it finds the new dock it doesn't update the new location of the new dock. Do I need to update the entire map or is there a simple function to switch the dock to a new area?
Did you start robot from the dock after changing the position? If the location of dock didn't update automatically, it is suggested to reset current map and do a full cleaning again to create a correct map.
I have the S5 version and i already moved the dock several times and after a while the icon upded in the map. After the 3.5.7_002008 upgrade that introced the rooms (many thanks for this option) i can't update the dock in the map.
I tried to restart the dock, vacuum, nothing solves.
I can't do the reset map now because i have works in my home and can't make the discovery. Exists any other way to solve it?
Thanks and regards
Hi, Mikyboy, may I suggest you reset the factory defaults and check if anything change?
Step 2. Use a pin to press the reset button next to wifi LED just once,and power button, recharge and spot cleaning button's light will be out. When you are doing this, please make sure recharge button is still under your finger's holding without moving.
Notice:
2. Factory default restore will also make RoboVac's firmware version come back to original one when it was made in factory. After factory default restore, you could go to RoboVac's setting--general setting--check for updates to upgrade its firmware to latest one.
Thank you.
I had exactly the same problem with my S5 (S552-0).
I followed the suggested procedure and now I get the message "boot failure - it will take about 5 minute to start restoring the initial version, please be patient" in loop. The device is inoperative.
Please advise!
Hi Pmduque, sorry for the inconvenience, for this issue, may I suggest you contact with support@roborock.com and send the details of the issue to them? we are afraid the problem won't be solved by a simple answer, and you could receive more troubleshooting via email Thank you.
