Amazon Alexa Support for S4 and MI app
When will this work ? I purchased S4 based on representation that Alexa voice would be available. Thank you.
  • Check attached file how you could link our device to alexa. The skill is called Roborock plus.
    Note: Make sure your robot is added and online on app Roborock(not Mi Home) first.
    After you integrate roborock account to alexa, it may not show robot discovered. Don't worry. Robot is integrared into alexa and you could refer to attached picture command to control robot.
    RR_SupportStaff Member01/14/2020      05:42
    Here is a picture of voice commands for your reference.
    Loaded4bear
    Loaded4bear01/14/2020      16:33
    I have a new S4 with the same problem. Alexa does not discover the S4.
    "it may not show robot discovered. Don't worry. Robot is integrared into alexa and you could refer to attached picture command to control robot"
    Not true. It does not work with any voice commands.
    RR_SupportStaff Member01/15/2020      03:08
    @Loaded4bear:
    May i know the server of your Alexa account ? please see attached picture.
  • Hi...the Roborock app is unstable on Android Moto G5 phone. Please see other forum entry on this issue. It's a fantastic vacuum, but I can't even get the Roborock Plus app the run for more than a minute until it crashes. What can we do to help you debug the app ? I submit the crash report every time. Let me know what more would help you get the app stable.
SLPMEP
