Hi, I bought a roborock s6 and I use it on a wet floor.
Then I turn it and wash it with water in order to clean it. Well I realize that I did a big mistake. After then it stopped working because of error 14, a battery error. What should I do?
We are sorry for the trouble you are facing. Robot cannot be washed with water.
It seems battery is faulty because of water damage. May i know where did you buy the robot?
