Error: 117 Left ODO error
Have enjoyed the S6 for about a month but this week the robot announced an internal error. I've reset multiple times but the 117 Left ODO error keeps showing.
    We are afraid there is something wrong with left wheel, may i know where did you buy the robot?
    Btw, it is suggested to contact support via email: support@roborock.com
    Walt
    Walt02/02/2020      12:11
    I bought it through Amazon Prime.
    RR_SupportStaff Member02/04/2020      04:44
    @Walt:
    Thanks for your info.
    May i suggest you contact us via email support@roborock.com and tell us amazon order number of S6?
    Walt
    Walt02/05/2020      15:53
    The Amazon order number is: 114-7600555-0348269.
    When I try to access the support URL it just takes me to the page with general info. Clicking on the support link/icon doesn't do anything.
    Thanks for the continued help.
  • I have the same problem with the S5. How can I resolve it?
    RR_SupportStaff Member02/20/2021      00:59
    @Daniel:
    If the internal error is related to the the wheel or ODO, please try the method below:
    1. Put the device on the ground, push it manually onward & backward for around 10 sec (like using an eraser). See video below:
    https://youtu.be/MiBkw_lcTF8
    2. When it feels like there's less resistance on the wheels, start cleaning again to see if it works.
    Notice:
    Manually pushing the device would cause an overheat of the motor. If it couldn't be handled within 10 sec, please wait for a while until the motor cools down, and try it again.
    Also, you can try to set the device to its factory version to have a try.
    https://youtu.be/bjSVEEgkVn0
    Step 2. Press the reset button next to wifi LED with a pin just once. Then the light of the power button, recharge and spot cleaning button will be out. When doing this, please make sure you're still holding the recharge button without moving.
Walt
