Hi all, I recently got my s5 Max after extensive testing against Roomba i7+ and Shark IQ. Very happy with it. I am using the workaround many have mentioned to have it clean my 2nd floor. My issue is it drains to 20% battery life just short of finishing the floor. Then it stops cleaning and looks for the base to recharge, which it can't do since its on my main floor.
Is there a way to turn off the re-charge and resume option so that the vacuum continues to clean past 20%?
Probably won't be an option, as you further discharge lipos, battery life significantly gets shorter. I'm sure it's all in the name of battery health. A better option would to not show people this "reserve" capacity.
We are sorry that it is not supported to turn off that option and robot will go back to dock when drains to 20% battery.
The multiple map saved function is not well made at present and could not meet customers' need, which is reason why don't say it supports multiple map saved. It is suggested to reset map every time and bring dock with robot when the robot is brought to another floor.
