frame
Roborock S6 no remote control on wifi
Hello
For some time now the remote control on the Xiaomi Mi Home app of S6 does not work
I am connected to the wifi of my home but still it does not work.
I recently updated to 3.5.4_1048 but that did not fix the issue.
Any ideas how to fix this?
Regards
Yannis
  • Hi, Yannls, Sorry for the inconvenience. would you please let us know whether your smart phone and robot are under the same Lan? Thank you.
    ianarus
    ianarus02/27/2020      11:29
    Yes when i try it both of them are connected to the same router
    ianarus
    ianarus02/27/2020      18:08
    @ianarus:
    @RR_Support
    So if I try to go to remote control i usually get a message that there is a wifi connexion issue try again later. whe in hit ok it takes me back to the previous menu
    If i try multiple times in a row eventually i might get through without having the messsage and the remote control will work.
    It is weird
    RR_SupportStaff Member02/28/2020      10:03
    @ianarus:
    Hi, The remote control can be used only when your device and your smart phone are under the same Lan. The your robot and your device are on the same lan, is it convenient to send us the details via our support@roborock.com? Thank you.
ianarus
