Roborock S5 and Vaccum Modes after FW 3.5.7_002008
Hi! After upgrade to latest FW I cannot find Vaccm Modes in the app (Turbo, Normal, Silent). A new option, Gentle mode, has been added, but does not change anything when vaccuming. Is the Vaccum Mode settings removed from the app with the lates FW?
I think the machine now runs in silent mode, and with no option to increase vaccum settings / intencity.
Hope you can help.
  • Dear customer,
    Please refer to the attached picture for where you could find the modes setting.
    And please kindly note the now "gentle mode" was previously named "mopping mode". They are of the same mode.
    Lucian
    Lucian06/04/2020      06:35
    It seems vaccum turbo mode is removed without any warning on update. How can I return to previous firmware? I want to use turbo mode from time to time when need a better cleanup.
    RR_SupportStaff Member06/04/2020      08:45
    @Lucian:
    Hi, could you please send us a picture of the cleaning modes?
    Meanwhile, is S5 the model number of your device? If yes, you can follow the instruction below:
    Step 2. Use a pin to press the reset button next to wifi LED just once,and power button, recharge and spot cleaning button's light will be out. When you are doing this, please make sure recharge button is still under your finger's holding without moving.
    Notice:
    2. Factory default restore will also make RoboVac's firmware version come back to original one when it was made in factory.
Bjarte
