frame
Automation
Roborock works in the mi Home ecosystem. The application makes it possible to connect multiple devices by means of automation. I would like to connect the 6-key switch with the roborock vacuum cleaner to control the cleaning of individual rooms. key 1 - bathroom, key 2 - kitchen etc.
Nowadays, the workrock allows you to configure the automation per room, but only in "timer" mode. Can you give access to the room selection in "automation" mode?
  • My motivation - makes roborock more accessible for elderly people.
    RR_SupportStaff Member03/20/2020      10:11
    @Epsylon:
    Would you please tell us the model of your robot? Below the picture will show you how to use automation. If anything unclear, please tell us or contact by email: support@roborock.com.
    Epsylon
    Epsylon03/22/2020      11:50
    Thank you for your answer. I own the roborock.vacuum.s6 and roborock.vacuum.s5. I know these automation options. My question is could you add in "then" section not only "start cleaning" but "room cleaning" option with room selection? Currently, the only possible automation is to clean the entire house/pause/go back to the dock
    RR_SupportStaff Member03/24/2020      08:59
    @Epsylon:
    Thank you for your feedback. Automation could not support room cleaning, but we will forward it to our tech department. And if you want to clean a single room only, the suggestion of us is that you could use "Timer", which is more convenient. Thank you.
Epsylon
