Cleaning products for moping
Hello. Is it ok to put cleaning products with the water inside the tank for moping? Thanks a lot
  • Hi, Lorena, Usually, we don't suggest our customers add anything into the water because the bubble made by chemical substance in cleaner may block the filter and cause no water out. Customers could give it a shot. If all is fine, we think it is OK to add. But if anything wrong on mopping, please clean the tank with water and don't use the cleaner any more.
  • Does anyone have any specific recommendations regarding cleaning solutions that they have added with success ?
    Thanks
    RR_SupportStaff Member03/28/2020      07:13
    @EAK:
    Some of our users succeed. You could have a try.And you could clean the vent of the water tank and the mopping cloth if cleaning products is unworkable.
    EAK
    EAK03/30/2020      14:49
    Used "Windex" on a tile floor seemed to work very well with no issues. Just poured it straight in to the tank then drained the leftover solution.
    venexiano
    venexiano05/24/2020      19:11
    @EAK:
    Which type of Windex please? The standard one for glass, or the multi-purpose that can be used for tiles? https://www.windex.com/en-us/solutions/tile/glazed-ceramic-tile
Lorena BB
