Roborock S50 : mapping issue... lost on floor
I have 2 vacuum robots at home (Roborock S5 and an Original Xiaomi Mi Robot Vacuum). The Xiaomi works great but the roborock makes strange and random runs.
I tried to move its base several times to see if it changes but without any noticeable success.
Any ideas?
Thank you for your coming help.
I join 2 maps of the same floor by the 2 robots on the same day...both robots are up to date according to the app, sensors cleaned.
Roborock KO
Xiaomi OK
  • Dear Customer,
    We are sorry for all the inconvenience.
    According to the map, we can see it has some overlapping on the map.
    1. How many floors do you have? If more than one, did you bring robot to different floor?
    2. Is there mirror on the ground of your house? Robot's laser may reflect on mirror and it will think there is room inside of mirror.
    3. Was map correct before with same house environment?
    4. Have you tried to delete current map as attached picture and try to create a new map?
    RR_SupportStaff Member03/31/2020      11:54
  • I have same problem with this map. It is overlapping and it is unable to find the room that i assigned it to. Let say i assigned it to clean the room on left, it goes somewhere else.
    There is no mirror in my house, i only use this vacuum on the same floor all the time. Map was correct before. I tried deleted the map and re-mapping. But it after a while, the problem re-appears
    RR_SupportStaff Member12/19/2020      08:47
    @Ametis:
    You can send us some problematic cleanup map for reference. Please mark the targeted room you selected.
    Use wet cloth to clean the wall sensor and cliff sensors; also you can move the dock's position to a more central area of the house and try again.
    Boonedocks
    Boonedocks12/30/2020      14:03
    Can you tell my why I have a perfectly functioning map (although the cleaning route makes no sense) and then all of the sudden the No-Go zones are all messed up. Nothing changed except the No-Go zones are off and the robot gets lost / stuck
    RR_SupportStaff Member12/31/2020      11:00
    @Boonedocks:
    Sorry to hear that.
    Could you send us some pictures for reference?
    Also, please send us the device info.
Lerig
