After installing the latest firmware, 3.5.7_002008, whenever I click on Zoned cleanup I get the message "Updating the map...", then it goes away and doesn't give the zone to move around like it did prior to the update. The same thing happens when I click on Go, the message shows up and no pinpoint appears. The only option that does anything is "Clean". Any suggestions besides resetting the whole unit?
Hi Ras1325, Sorry for the inconvenience. Would you please try below methods:
If the problem is still exist, would you mind send the details to support@roborock.com?
Clearing the cache did the trick. The app looks completely different now.
Please kindly try to recreate a new map:
1. Map saved mode is enabled, see attached pic.
2. Robot starts from dock;
And if the problem still exist, please kindly list all the details to support@roborock.com, and they will give you more solutions about this issue.
Thank you.
