Not optimal cleaning route S5 MAX
My S5 MAX cleaning hall (named Hol in this picutre) using not optimal ( old ? ) cleaning route
Question is why ? S5 MAX should clean along the long side, not across. Am I right ?
  • Hi Vant, The orientation of the cleaning route is depends on the algorithm of the environment, the robot will find the best route to clean the house. if you want to change the orientation of the route, the suggestion of us is that you could change the dock's position. Thank you.
    VANT
    VANT04/17/2020      09:06
    thanks for reply
    RR_SupportStaff Member04/18/2020      07:57
    @VANT:
    You're welcome, hope you have a rainbow weekend~~
VANT
