S5 Max Water Tank Pipe Problem
Hi I just bought S5 Max 3 weeks ago, and I just notice today that the translucent pipe inside water tank not attached to the water hole, that's why everytime I use for mopping no water come out after water level below water hole.
I follow instruction to blow air holes and try to suck water hole and also use needle to check dripping holes in unit, everything is good.
Model : roborock.vacuum.s5e, Serial number : R0518S00100859.
How to solve this problem? The plastic pipe just lay down in the bottom of the water tank. 😁
Thank you.
  • Anyway to buy water tank S5 Max or this can be fixed or claim?
    RR_SupportStaff Member04/24/2020      07:18
    @Johan:
    Hi, Johan, Sorry for the inconvenience. sorry that we think it cannot be fixed by yourself, so the suggestion of us is that you could purchased a water tank of it. Thank you.
Johan
