Cannot connect S5 Max with Roborock app
It stuck at this step. Robot cannot connect to Wifi (2.4Ghz). But when I use Mi home app. It can connect Wifi. However I need to try to use Roborock app. Can you resolve my problem?
  • Dear Customer,
    Your case is quite rare to us. May we ask if the issue has been resolved.
    If not, could you please contact us through our support email, support@roborock.com. We may need more information and involve the tech team for the issue.
  • I had this too.
    The issue was with my mobile. I use a Firewall on android (NoRootFirewall) and while I let the app talk to the internet, there's some other process that the firewall was blocking.
    I disabled the mobile firewall, flushed the app cache, reset the WiFi on the vacuum and then tried again. Worked fine after that. I re-enabled the firewall and it all works fine. It was only in the setup that it needed the security relaxed a bit..
    I hope that helps (took me a couple hours to figure it out myself)
    CW
    RR_SupportStaff Member05/11/2020      09:21
    @CallumW:
    Thank you for your kindly suggestion, and we think it's a good may to try it, we will collect your suggestion and we think it may also helps our other users. Thank you again.
Tita
