after the update firmware charging problem fixed, thanks to u, but now the roborock won't go under my bed, the roborock just clean the space around the bed. Before the update the roborock would go under my bed and clean the area, I need this function cause it's hard to clean under bed. Please fix it
Dear Customer,
If you do think the issue is caused by firmware update, we suggest you restore device to factory default.
Step 2. Use a pin to press the reset button next to wifi LED just once,and power button, recharge and spot cleaning button's light will be out. When you are doing this, please make sure recharge button is still under your finger's holding without moving.
Notice:
2. Factory default restore will also make RoboVac's firmware version come back to original one when it was made in factory. After factory default restore, you could go to RoboVac's setting--general setting--check for updates to upgrade its firmware to latest one( if you want the previous firmware, you could choose to stay with the previous one and not update it).
The problem solved my roborock will go under my bed now after resetting to the inital firmware, but now evertytime i open the app it offer update firmware or quit, then i press back button and can get into the app but I can do nothing, I can't change the voice to english and can't see the map, the app just display " getting info" and "Map Loading", I have pressed the "menu button" on the top right corner and nothing happen. Please help me
3. Take the robot off the charging dock, reboot it by long hold the power button and run the app again to see if it works.
4. What is the size of your house? not size already cleaned, but your house's whole size.
5. If you are using Mi Home, tell us which region your Mi Home selects and switch region to the US or Singapore, then re-connect the robot to Mi Home. See attached picture.
6. Clear cache of app. See attached picture.
7. Reinstall app to have a try.
8. Pls use your phone data instead of wifi to see whether map will show up.
9. Do you have any other Xiaomi's device, like camera, lamp?
because of can't see the area which my robot has cleaned i pressed update firmware and it back wont't go under my bed again. Ok I'll try again set it to the initial firmware again. My home is about 250m2, my serial number R0001S84300173, firmware 3.5.7_002008
I have reset itu to the initial firmware and now the problem back again: I can't see which location that has been cleaned by the robot and it just displayed " map loading" although robot working fine, and when I press the menu button on the top right nothing happen. Answering your question :
Try to hard reset it once more time and re-add it to the home wifi. You can move the dock's position to a more central area of the house.
If it is still the same, you can update the firmware to the latest one and we can do some troubleshooting about the original issue mentioned in subject.
