frame
Roborock 1
I bought an initial roborock 1 from gearbest and liked it so much I ended buying 3 more for different locations (though I havent used 2 yet). I am generally a little paranoid about intslling android apps sharing homelayouts, passwords of routers etc. and hence I did not install the app initially. I have installed the Xiaomi Home now but it does not seem to have anything other than notifications, on , off and schedule and you cannot see the mapping. I am not desperately keen to go to latest firmware though I have gone to 3.3.9_003600
Is there a manual to show me how to use the app. Is the original map showing room layouts etc still available?
  • Also I am not sure if one of them charges and the white light does not glow? Is there a way of checking. I am using a charger that I know works
  • Dear Customer,
    May I know what is the model number of your vacuum?
    You need connect the vacuum to the host wifi and create a map by doing a full cleaning.
    The indicator light on the dock should be solid on without robot and should be off with robot.
TA
