Vacuum and mop simultaneously?
I have been separating the tasks (I'll vacuum 3x/wk then mop). Can I do both at the same time and not run it 4x/wk, or do you have to do them separately?
  • Dear Customer,
    You can vacuum and mop at the same time.
    Actually, there is no switch to only disable mopping or vacuum feature and just let one of them work.
    Once robot is moving, vacuum begins working.
    Once robot is moving and mopping attachment installed, mopping begins working.
    If you hope it vacuums only, you could only uninstall mopping attachment, and there is no way to make robot mop without vacuum.
thaKing
